Cyclone 10 GX FPGA Development Kit - Bug in Pin Assignments
- 3 years ago
There is no bug in pin assignments. The positions of LED[0] & LED[2] are swapped on the board so this has caused confusion.
As we know from Table 13 of the user guide, the board reference of the USER_LED sequence are as follows:
D22: USER_LED3
D19: USER_LED0
D20: USER_LED1
D21: USER_LED2
User guide here: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-c10-gx-fpga-devl-kit.pdf
And the pin locations corresponding to these board references are as follows:
D22 (LED3): AC7
D19 (LED0): AF6
D20 (LED1): AE6
D21 (LED2): AC6
If you look at the board, you can see that the positions of LED2 & LED0 are swapped and the sequence are just like above.
I hope this clarifies your confusion.
Nurina
D22: USER_LED3
D19: USER_LED0
D20: USER_LED1
D21: USER_LED2
D22 (LED3): AC7
D19 (LED0): AF6
D20 (LED1): AE6
D21 (LED2): AC6
Nurina
- MatthiasMeyer3 years ago
Hello Nurina,
thank you very much for the detailed and helpful response.
I did not expect this counter-intuitive numbering of the leds on the board.
Thanks again,
Matthias.
