MostafaGhouneem
4 years agoCyclone 10 GX FPGA (10CX085YF672E6G) IO PINs
I have Cyclone 10 GX FPGA (10CX085YF672E6G). This FPGA has 3V IO bank which supports single ended and differential SSTL ,HSTL, and HSUL I/O standard up to 3V. We want to know if we can use its differ...
AqidAyman_Altera
4 years agoYes, it is correct. You can choose the I/O standard you want to assign to those pins through the Quartus Pin Planner.
Intel® recommends that you create a Intel® Quartus® Prime design, enter your device I/O assignments, and compile the design. The Intel® Quartus® Prime software will check your pin connections according to I/O assignment and placement rules. The rules differ from one device to another based on device density, package, I/O assignments, voltage assignments, and other factors.
You can always refer to the I/O Standard Specifications for various I/O standards supported by Intel® Cyclone® 10 GX devices. through the link.
