Cyclon IV qdz file compatible with Quartus
- 3 years ago
Hi everyone,
Finally found the solution:
Use the .qdz file provided from Intel website for Cyclone IV, with the compatible Quartus version (in my case, Prime 22.1std)
Create project for the device EP4CGX150DF31C7
In the programmer, use auto-detect button that show EP4CGX150 and EPM2210.
Right click on EP4CGX150 and "change file". Choose the .sof file created by the project.
It will remplace the EP4CGX150 by EP4CGX150DF31C7, and allow you to configure/program this device.
If you start the flashing process, it should work.
(EPM2210 is unused in my case, left there for Quartus to be happy)
Thanks your help !
Looking at the manual for that dev kit, it says the main device is a EP4CGX150DF31 and the screenshot of installed devices shows that that is available in different speed variants (C7 and C8). Just pick one of those. Not sure where you're getting "150F01989".
