Adibbi
4 years agoCPU1 not found on 5CSEBA2U23C6N (should be dual core)
our Cyclone V - 5CSEBA2U23C6N fails to de-assert the second cpu core from reset. During boot Linux reports the message "CPU1: failed to come online". Software on the SD card is generated by Yoc...
tehjingy_Altera
4 years agoHi Adibbi
From the part number of the CV chip it should come with dual core.
It is weird that CPU1 is not coming online.
There are no settings to turn on/off the cpu core manually.
Which branch of the meta-intel-fpga layer that you are using? Is it the latest stable barnch?
In your current branch, could you check the device tree node for the Cyclone5 is following:
hps_0_sysmgr: sysmgr@0xffd08000 {
compatible = "altr,sys-mgr-15.0", "altr,sys-mgr", "syscon";
reg = <0xffd08000 0x00000400>;
cpu1-start-addr = <4291854532>; /* embeddedsw.dts.params.cpu1-start-addr type NUMBER */
}; //end sysmgr@0xffd08000 (hps_0_sysmgr)
4291854532 == 0xFFD080C4
Jingyang, Teh
