Converting .sof file to .flash file for Stratix 10 GX development kit
I hope you have update. As of now, we might not be able to get the Board Update Portal script for the new Quartus version in the shortest of timeline.
So our suggestions is if you are able to use the Quartus version 18.1~ - 19.1 to use the script?
Additionally, for S10, the SDM the security device manager should be use as an advantage if you are porting from A10, so using the Board Update Portal isn't ideal to utilize it's full potential, as it is intended more towards a taste of the Quick Start Guide.
Moving forward towards RSU is my ideal suggestions, I understand it may require further understanding, however you may file any new thread on any questions on the RSU and we will help your there, on security/SDM, config etc.. So let me know your thoughts.
Hi, sorry for the slow replies I am on work travel currently through next week and will be back in the office on Aug 11th.
I am using Quartus Prime Pro, 23.1. I can check with IT about installing an earlier version, however it may not work as the disk space required for each version of Quartus is significant.
As long as I manually generate the .pof using PFG and then manually type the sequence of commands in from the end of the script, I can get the commands to generate the file as well. However it still does not work upon uploading through the Board Update Portal.
When I get back from this long travel, Ill take a closer look at the RSU and see if I am able to figure out the steps there and get one of my boards loaded with the user design through that method.
