Converting .sof file to .flash file for Stratix 10 GX development kit
Hi Chris,
Not a problem, we would like to help our users to get the best experience, we apologies for any inconvenience.
We are working now on finding the right fix for the S10 boards starting with the script itself.
In the meantime, just to reiterate, it would require first the .sof to .pof of your design. By using the Quartus PFG not Quartus CPF, I think. We do need to get the .hex for the bootloader using the Quartus PFG however, for S10 steps, we have the build flow here to get one:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloader
Then convert the .pof to .bin for the Board Update Portal.
But the side is currently down.
We will keep you updated on anything from time to time, we appreciate your patience.
Just to check again, you are facing this syntax previously?:
xxd: ghrd_1sx280lu2f50e2vg.pof: No such file or directory
expr: syntax error: missing argument after ‘length’
expr: syntax error: unexpected argument ‘2’
dd: invalid number: ‘’
Object file generated successfully!
