cconger
3 years agoConverting .sof file to .flash file for Stratix 10 GX development kit
Hello Intel,
I have the Stratix 10 GX development kit, and am needing to load a user design into the Flash for auto-configuration of the user design at power up. I've been following through the d...
EBERLAZARE_I_Intel
3 years agoHi,
I have run through again the steps, for BUP for Stratix 10 it should be for the Hardware using ".bin" file generated using the "build_hw.sh your_sof.sof" command which will create a .bin as output as per the "build_hw.sh script", as per the document, and the Software if any, using ".flash".
Whereas, for Arria 10, it should just be ".flash" only.
Currently, I am having issue with the Nios II command shell using the script to generate the .bin for the Hardware.
Again, I apologies for the extended confusion on this issue, as we do not get Board Update Portal questions.
