cconger
3 years agoConverting .sof file to .flash file for Stratix 10 GX development kit
Hello Intel,
I have the Stratix 10 GX development kit, and am needing to load a user design into the Flash for auto-configuration of the user design at power up. I've been following through the d...
cconger
3 years agoThank you. Note that I am using Windows 11, and Quartus Prime Pro 23.1.
Also, if I try to convert the .sof into a .pof using File -> Convert Programing File, I get the following error from Quartus:
Error(20687): Convert Programming Files does not support the target device 1sg280lu2f50e2vg. Please use Programming File Generator to generate the programming file for the target device.
So it seems this device isn't supported for conversion anyways. This is a confusing process for a very basic need to have an FPGA auto-configured at power-up. Any help would be greatly appreciated!
