Connection of Stratix 10 GX FPGA Development Kit
Standard Windows driver installation if you didn't choose to install/update the drivers during Quartus installation. Go through device manager and point to the drivers directory.
- jamesjjc3 years ago
Thanks! I just installed the driver and that "Altera USB blaster driver II" successfully showed up in my device manager.
But I still cannot open the board test system. I followed the instructions as this web.
Do I need an Ethernet cable to connect my PC and the board?
Thank you!
Now I use the older version, Quartus Prime Pro 17.1. When I open BTS, the system says "FPGA mismatched". But I can open the ClockController and PowerMonitor.
Here's the log file.
十月 27, 2022 8:31:38 上午 com.intel.bts.BtsView <init>
資訊: Board version: Rev D, chip version: HTES
十月 27, 2022 8:31:39 上午 com.intel.bts.ClientApp attachServer
資訊: [C:\intelFPGA_pro\17.1\quartus/sopc_builder/bin/system-console, --server]
資訊: Here is the standard output of the command:
十月 27, 2022 8:31:40 上午 com.intel.bts.ClientApp attachServer
資訊: TCP PORT: 50351
十月 27, 2022 8:31:46 上午 com.intel.bts.JtagInfo createDeviceInfoMapArray
資訊: 2 device detected: /devices/5M(1270ZF324|2210Z)|EPM2210@1#USB-1 /devices/C32250DD@2#USB-1
十月 27, 2022 8:31:46 上午 com.intel.bts.ClientApp getMatchedBoardInfoArray
資訊: System Max matched: true, Fpga matched: false
十月 27, 2022 8:31:46 上午 com.intel.bts.BtsView startMainStage
資訊: Selected JTAG cable is: USB-BlasterII on localhost (USB-1)Could you please explain what's happenning? Thanks.
