APaci1's avatar
APaci1
7 years ago
Connecting 2 TSE (with micrel PHY) each other: Link down
i! I have my Arria10 custom board
2x TSE-PHY MICREL-Ethernet Ports A,B
A,B linked to PC NIC works fine (I send and transmit frames from PC to TSE and vice-versa) , I see 100 Mbps, Full Duplex, Auto MDI/MDI-X default enabled
Connecting TSE A to B with same crossed cable already tested before, PHYs never goes up!!!!
There is another manouvre to do to wakeup TSE-PHY???
Thanks to everyone knows this question!
  • APaci1's avatar
    APaci1
    this is capture on avalon side, any frame with MAcD different from Primary MAC enter anyway... :-()
  • SengKok_L_Intel's avatar
    SengKok_L_Intel
    For unicast address, bit 0 of the destination address is 0, but for your case the bit 0 is 1 (F). Could you please try the address below?
    mac_0 = 0xccddeeff
    mac_1 = 0x0000aabb
    Or
    mac_0 = 0x42E90700
    mac_1 = 0x000028AC
  • APaci1's avatar
    APaci1
    Thnaks, I try set TSE_MAC Addr 0/1 and all secondary Macs to mac having 0 on lsbit as you suggest, but on avalon side results is the same, I receive all macs that arrives on this network segment... :-(
    SengKok_L_Intel
    ​I have run the simulation and confirm the address filtering is working fine from my site.
    Could you please try the following setting, and read back the register to confirm?
    1. Address 2 command_config = 0x048002b
    2. Address 3 MAC_0 = 0x22334450
    3. Address 4 MAC_1= 0x 0000EE11
    Could you please also refer to the link below, section 5.3.1 and follow the recommended initialization sequences?
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf
