RThie6
7 years agoCan't get DE0 nano board to boot from EPCS with NIOSII code running from SDRAM
I have made several attempts to make DE0 nano boot from flash (epcs64) with a Nios II and code running from SDRAM. In the mean time I have tried all tutorials, every trick posted over the several yea...
- 7 years agoposted a file.
FawazJ_Altera
7 years agoHello,
My apologize for the late reply. I was looking for a DE0 nano board to test the design, and luckily, I found one. I could test the design on board and its booing from EPCS without any issue.
I will attach the design to help you settle the issue.
Thank you
BXia
4 years agoHi Fawaz,
I tested the attached project with my DE0-Nano board, I had a error when using the Flash Programmer to program the EPCS device, could you help checking the issue? I attached the error information here.
By the way, could you teach me how you generated the .jic file for this project?
Thanks in advance.
