RThie6
7 years agoCan't get DE0 nano board to boot from EPCS with NIOSII code running from SDRAM
I have made several attempts to make DE0 nano boot from flash (epcs64) with a Nios II and code running from SDRAM. In the mean time I have tried all tutorials, every trick posted over the several yea...
- 7 years agoposted a file.
RThie6
7 years agoMany thanks for your reply and links. I can perfectly run the program in SDRAM form the debugger (eclipse). I can perfectly make a bootable epcs64 system when nios is running from SRAM (and NOT SDRAM). It's the combination of getting it to boot from EPC and rund code/data from SDRAM that is the issue. I know the hardware boots from EPCS.. but for some reason the code isn't loaded into Sram or not booted... all parameters are set correct according to Intel manual... So problem persists
