Can't get DE0 nano board to boot from EPCS with NIOSII code running from SDRAM
- 7 years agoposted a file.
I have done this long time ago. You need to maintain two important things:
1- The clock that feeds the SDRAM should be shifted around -3 nano seconds.
2- Use Older Quartus Programmer version instead of 18.1, for example 15.0
Page 11 of this document shows the PLL time shift to handle the SDRAM timing issue:
This document below, shows how to program the EPCS of DE0-nanop
ftp://ftp.intel.com/Pub/fpgaup/pub/Intel_Material/17.0/Tutorials/DE0-Nano/Using_DE0-Nano_Flash.pdf
- RThie67 years ago
Many thanks for your reply and links. I can perfectly run the program in SDRAM form the debugger (eclipse). I can perfectly make a bootable epcs64 system when nios is running from SRAM (and NOT SDRAM). It's the combination of getting it to boot from EPC and rund code/data from SDRAM that is the issue. I know the hardware boots from EPCS.. but for some reason the code isn't loaded into Sram or not booted... all parameters are set correct according to Intel manual... So problem persists
