Can't flash a sof file to Cyclone V E development kit by using JTAG protocol through programmers too
- 3 years ago
Hi WZ2,
thanks for your response. Now I am able to flash .sof file using JTAG protocol. Actually I didn't set the DPI switch 2 properly. When I on on on on of DPI switch 2 then JTAG protocol worked properly.
Sameer
Glad to see the problem solved! The Jtag has the highest priority to config, the setting of SW just make sure that when you power up the board, there is no other config file download into cram~ I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
