Cannot Instantiate Cyclone V In platform Designer
I am trying to instantiate Cyclone V hard processor in platform designer, but I am getting this error:
Error: new.hps_0: list element in quotes followed by ":" instead of space
while executing
"llength $db"
("if" test expression)
invoked from within
"if {[llength $db] != $PASSED_LIST_SIZE} {
return 0
(procedure "::pin_mux_db::load" line 26)
invoked from within
"::pin_mux_db::load $device"
invoked from within
"set load_rc [::pin_mux_db::load $device]"
(procedure "ensure_pin_muxing_data" line 20)
invoked from within
"ensure_pin_muxing_data $device_family"
(procedure "validate" line 4)
invoked from within
"validate"
(procedure "compose_logicalview" line
invoked from within
Could someone please let me know why is this?
- sstrell
When and where exactly are you seeing this? Is the target device for your project an SoC device?
- Athira0311
I am using DE1 SoC board, when I am trying to add The hard-core processor, it shows this error
- sstrell
Can you confirm that your target device is an SoC variant? If the target device is not set correctly, you won't be able to add the HPS IP.
- Athira0311
yes, the board is an SoC variant, DE1-SoC Board
- sstrell
I’m not talking about the board. I’m talking about the target device you selected in the Quartus project.
- EBERLAZARE_I_Intel
Can you provide the screenshot of this error? Where exactly did this error reported in Quartus/Platform Designer?
Do you have any update?
Can you check my previous respond?
- Athira0311
Could you give me the design, I would like to replicate from my side.
Are are you able to replicate the same error again on any new "dummy" design every time? Which other Quartus version are you seeing the error?
I am just checking, do you have update from your side?
Please check your license or try using Quartus lite version or try create a new project.
Alternatively, you may use the GHRD for your design to try:
https://www.rocketboards.org/foswiki/Documentation/CycloneVSoCGSRD
