Cannot complete the linaro part
I am Jerry Jacob. I attempted to use the SoC EDS 20.1 version 711. I used this link https://www.rocketboards.org/foswiki/Documentation/SoCEDS#Install_SoC_EDS_AN1 . I was able to install Cygwin properly. I also did install MinGW too.
However, when I attempted to install Linaro using ./install_linaro.sh, I get the following error shown. Hence, I couldn't run the SoC EDS as per the procedures given in the link.
Kindly help me in this situation.
Thanking You
Yours Sincerely
Jerry Jacob
- jjac705
Hi JingyangTeh,
I got the MYSYS and I attempted everything as per the instruction given on this link https://www.rocketboards.org/foswiki/Documentation/HWLib#Setup_HWLibs.
I tried the first three steps as per the MYSYS part. I attempted to do the ./install_linaro.sh. I got the following response.
I am not sure whether this is right or wrong. But it took a long time to get this one. I checked the files and there is new file called intel-socfpga-hwlib which comprises of the following
On clicking on tools, I got the following,
What I can see is is now there is a new file called "newlib" and "newlib-cygwin". As per the instructions given, it says that the installation of linaro will setup Linaro toolchain, newlib and cygwin in your system.
Do you want to check anything else? Do let me know.
Thanking YouYours Sincerely
Jerry Jacob
- tehjingy_Altera
Hi Jacob
The folder structure looks about right. The linaro have been compiled successfully.
You could double check your PATH environmental variable. the gcc path will be part of it. If it is not there you could manually add it in using the command : " export PATH=`pwd`/gcc/bin:$PATH"
Jingyang, Teh
- jjac705
Hi JingyangTeh,
I have used the above command.
I checked the above mentioned path too and got these gcc, newlib,newlib-cygwin and others mentioned below.
It seems there is a gcc in the above mentioned path.
I already have ARM DS 2020.1 installed. I have a Cyclone V SoC (SoCkit). I have a WSL in Windows 10 too.
Kindly guide me on how to do the following steps too.Thanking You
Yours Sincerely
Jerry Jacob
- tehjingy_Altera
Hi Jacob
Could you please elaborate what steps you are referring that you need help on?
Currently you are all set to do baremetal compilation.
Jingyang, Teh
- jjac705
Hi JingyangTeh,
I was attempting to do this link https://www.rocketboards.org/foswiki/Documentation/HWLib?elq_cid=7076518_ts1675282356531&erpm_id=102... in Quartus 20.1 Prime Standard Edition.
I was able to successfully compile Linaro on MSYS. However, when I attempt to run the Uboot, I am a bit puzzled when they say run the terminal and do these.
I checked this link too https://www.rocketboards.org/foswiki/Documentation/CycloneVSoCGSRD#Release_Contents and I attempted to write the SD card too and my PUTTY shows something like this
I am using an SoCkit for Quartus Prime 20.1 Standard edition. I an unsure about the way forward.
Thanking You
Yours Sincerely
Jerry Jacob
- tehjingy_Altera
Hi Jacob
The wording at the rocketboard are not correct.
You do not need to open a terminal to your board. The command there should be entered into the MSYS terminal.
Jingyang, Teh
- tehjingy_Altera
Hi Jacob
Any update on this?
Is your linaro compiler working properly?
Jingyang, Teh
- tehjingy_Altera
Hi
Since a solution have been provided and no feedback was received, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
