Amir3
4 years agoAvalon MM BUS - are there saved addresses?
Hey,
there are saved addresses in Avalon MM BUS when Nios2/f is the master?
I'm asking because when I click in Platform Designer on "Assign Base Addresses", the tool change the Addresses of "ep...
RichardT_altera
4 years agoDue to Intel confidential, I am not able to share the details on how the code working behind the "Assign Base Address" command unfortunately. Nevertheless, if you have any issue/bug with the design, you may file a new thread to get the technical support.
