Amir3
4 years agoAvalon MM BUS - are there saved addresses?
Hey,
there are saved addresses in Avalon MM BUS when Nios2/f is the master?
I'm asking because when I click in Platform Designer on "Assign Base Addresses", the tool change the Addresses of "ep...
RichardT_altera
4 years agoWell, good thing is that the problem resolved for now.
I believe I have answered your inquiry.
Do you need further help in regards to this case?
- Amir34 years ago
I would be happy to receive an unequivocal explanation about the mechanism that works under the "Assign Base Addresses" operation in Platform Designer. For example, why start from an offset like 0x0200_0000 in addresses and more..
Anyway, thanks for your help!
