Amir3
4 years agoAvalon MM BUS - are there saved addresses?
Hey,
there are saved addresses in Avalon MM BUS when Nios2/f is the master?
I'm asking because when I click in Platform Designer on "Assign Base Addresses", the tool change the Addresses of "ep...
RichardT_altera
4 years agoThe tool command have an algorithm behind it, and for how the tool calculate or determine it, I don't know about the details unfortunately.
If the address assigned works, I usually goes with it. Any concern with using the assigned base address?
