Amir3
4 years agoAvalon MM BUS - are there saved addresses?
Hey,
there are saved addresses in Avalon MM BUS when Nios2/f is the master?
I'm asking because when I click in Platform Designer on "Assign Base Addresses", the tool change the Addresses of "ep...
sstrell
4 years agoI don't know this for sure because I haven't experimented with it, but based on your example, the command may be trying to minimize the size of gaps in the address map instead of just always starting from 0. You still have a gap, but it's obviously smaller with that interface starting at 0x2000000.
