Arria V GX with HSMC Debug Header Pins
I have the Arria V GX starter kit and I would like to connect a microphone breakout board to the HSMC debug header. I do not understand how the 40 pins on the HSMC debug header translate to the 160 pins from the FPGA. I would like to know which pins are on the HSMC debug header in terms of the 160 HSMC pins.
Thank you!
- Deshi_Intel
HI,
Are you referring to the HSMC connector on starter kit board ?
You can always refer to board schematic doc available in "kit installation" to trace the connection on which FPGA pin is connected to which HSMC pin.
- https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-arria-v-starter.html
dlim
- jlanier
I'm actually interested in the Debug board pins. There are 40 and I'm wondering if I can use them as GPIO. I'm trying to hook up a microphone so I will need a Clk, Data, GND, and 3.3V. I know there are 2 GND pins on the Debug board but I am unsure what the other pins are capable of.
- Deshi_Intel
HI,
I don't have AV starter kit board and its accessory so it's hard for me to visual what's debug board that you are referring to here.
I believe it's additional small card that can connect to HSMC connector (J13) on AV starter kit board.
I found the HSMC debug header card schematic as per attachment. You should be able to trace back the debug header card pin connection back to Arria V FPGA now.
dlim
- Deshi_Intel
HI,
Hopefully you are able to proceed with your project development now with the schematic that I shared.
For now, I am setting this case to closure.
Feel free to file new forum thread if you still have enquiry in future.
dlim
