jd23
3 years agoArria 10 SoC FPGA Development Kit Not Configuring FPGA on Boot
I am currently working with an Intel Arria 10 SoC Development Kit https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/arria/10-sx.html.
After following the inst...
Jeet14
3 years agoHi,
When you are using the SD card make sure you had checked below options as well.
First, confirm the following:
- DDR4 memory card is installed on the HPS Memory slot
- Micro SD boot flash card is installed on the Boot Memory Daughtercard slot
Then, the board switches need to be configured as follows:
- SW1: OFF-OFF-ON-ON
- SW2: All OFF
- SW3: OFF-ON-ON-ON-ON-OFF-OFF-OFF
- SW4: All OFF
Also, the board jumpers need to be configured as follows:
- Leave the SD Card boot card jumpers placed in their default configuration
- On the development board:
- Place jumpers J16, J17
- BSEL0(J3) = 1 (left)
- BSEL1(J4) = 0 (right)
- BSEL2(J5) = 1 (left)
- Leave all other board jumpers unplaced
Also, did you tried with another SD card?
Tiwari
- jd233 years ago
Thank you for your response.
We have checked the options you mentioned, and the settings are correct. We have also tried 2 different SD cards already.
Do you have any files that we could use, maybe via the JTAG interface, to program the FPGA and see if it will configure. We have not been able to get the board to configure with the GHRD, and have not seen the green done light come on at all.
Thank you!
