RubenPadial
Contributor
3 years agoArria 10 SoC DevKit: LED D17 (Error) is ON
I'm following Arria 10 SoC Development Kit User Guide and I would like to run the Board System Test. It is the first time board is powered on. SD seems to have an starting image. It contain...
RubenPadial
Contributor
3 years agoHello @aikeu
The configuration you sent in the previous message correspond to Arria® 10 GX FPGA development board. To run BST I followed instructions given in Arria 10 SoC Development Kit User Guide 4-2 (https://www.intel.es/content/dam/altera-www/global/en_US/support/boards-kits/arria10/soc/es2_files/A10-SoC-DK-UG_2.pdf) as I explained before. I was done after building SD card with https://www.rocketboards.org/foswiki/Documentation/Arria10SoCGSRD instructions because default SD doesn't work.
