Arria 10 SoC DevKit: LED D17 (Error) is ON
Hi RubenPadial,
I think there is nothing happened after you run the linux hello application because the one that you built does not have it.
Try the pre-built verison using the Creating SD Card on Windows on the link you have shown previously,
https://www.rocketboards.org/foswiki/Documentation/Arria10SoCGSRD
1. Download and uncompress the SD card image from https://releases.rocketboards.org/2022.12/gsrd/a10_gsrd/sdimage.tar.gz The extacted file is named gsrd-console-image-arria10.wic.
2. Rename the wic file as sdimage.img
3. Use Win32DiskImager to write the image to the SD card.
The system should able to boot up normally and able to execute the hello application.
Aik Eu
This was already done. Examples from https://www.rocketboards.org/foswiki/Documentation/Arria10SoCGSRD are now working. I was not able to communicate with the board becasu I was using the wrong ending charater, that is not spcified in the guide. CR ending character is needed. However "Board System Test" doesn't work. I receive the following message: "The sof file is not exists!"
