RubenPadial
Contributor
3 years agoArria 10 SoC DevKit: LED D17 (Error) is ON
I'm following Arria 10 SoC Development Kit User Guide and I would like to run the Board System Test. It is the first time board is powered on. SD seems to have an starting image. It contain...
RubenPadial
Contributor
3 years agoHello,
I have built the SD card image according to this guide https://www.rocketboards.org/foswiki/Documentation/Arria10SoCGSRD and now is working. I can read "No IP obtained ALTER:COM/SOCQS" in LCD screen. However when I execute Board System Test, I receive the following message: "The sof file is not exists!"
I changed switch status accroding to Arria 10 SoC Development Kit User Guide 4-2:
- SW1: ON-OFF-OFF-OFF
- SW2: All OFF
- SW3: OFF-OFF-ON-ON-ON-OFF-ON-OFF
I addition, following the instructions from Running Sample Linux Applications secction from https://www.rocketboards.org/foswiki/Documentation/Arria10SoCGSRD I do not receive any answer when I send
root@arria10:~# cd /home/root/intelFPGA
root@arria10:~/intelFPGA# ./hello
