RubenPadial
Contributor
3 years agoArria 10 SoC Development Kit: FMC-I/O Card
I'm using Arria 10 SoC Development Kit and I need some more I/O with debugging purposes. I read about using FMC interface to get more I/O. For example Xilinx has a specific card to uses FMC ...
NazrulNaim_Intel
3 years agoHello,
Regarding your enquiry, you can use signaltap in the Quartus software where it can view the internal signals of the FPGA running on your board without using external measurement equipment.
Nazrul Naim
- RubenPadial3 years ago
Contributor
Hello @NazrulNaim_Intel,
The solution you suggest is to see internal signal. I need to access to each FMC I/O individually like in the Xilinx board of the first message. Is there any Intel alternative or any compatible board?
