fpga_2022
4 years agoArria 10 SoC - Boot from SD Card
hi,@EBERLAZARE_I_Intel,i do run "make generate_from_tcl" first。
i want to reply you, but,the reply button is not work。
- EBERLAZARE_I_Intel
Can you share your full design and I try them from my side?
If you still having issue with the reply button, can you attached the design in email along with this link, to my email: [email protected]
We may proceed with the communication there.
Update:
Case is solved via email:
- Why cannot run "make generate_from_tcl" and "make rbf" / "make sof" in https://rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10 :
Unfortunately above commands are not supported to be executed in WSL, only in Linux, you can install a Virtual Machine, and do the commands.
- How to convert sof to rbf:
You can follow the split rbf steps above.
- When running "tools/mkimage -E -f board/altera/arria10-socdk/fit_spl_fpga.its fit_spl_fpga.itb" I get "sh: 1: dtc: not found"
To solve:
sudo apt-get install device-tree-compiler
