fpga_2022
4 years agoArria 10 SoC - Boot from SD Card
hello,
I executed make generate_from_tcl according to the documentation, but it reported an error /home/hh/intelFPGA_pro/21.4/nios2eds/nios2_command_shell.sh: line 187: exec: make: no...
tehjingy_Altera
4 years agoHello Sir,
Could you check the current directory when you are calling the "nios2_command_shell.sh" script?
It should be the same directory level as "a10_soc_devkit_ghrd".
If there is still and error could you please provide the command logs for me to look into it more detail.
What is the operating system that you are running?
Another thing you should take note is to setup the license for the Quartus Prime Pro before running the "nios2_command_shell.sh" script, if not there will be some unexpected error that could happen when you do the make.
Jingyang, Teh
