Y_S1
4 years agoArria 10 Resetting with core temp at ~70Deg C.
Using Arria 10 (10AX027H3F34E2SG). This works fine (for hours) till the die temperature is below 70 Deg C, and resets above 70 Deg C. As per the data sheet this probably should happen at a higher tem...
AqidAyman_Altera
4 years agoHello Ajay Sharma,
I do not receive any response from you to the previous answer that I have provided.
This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
