IanD
3 years agoArria 10 hold violations
Using an Arria 10 board. Setup timing is clean, but I'm getting a few hold violations from the Arria PHY to an input FIFO. Clocks are correct and the violation only shows up sometimes. I.E -...
RichardT_altera
3 years agoDo you mean the hold violation occur sometimes? Do you get it to pass timing before?
If so, it might be marginal issue. Try to run seed sweep to get the best fit that close timing.
Do you have enough positive slack for setup? You can set "All paths" in the "Optimize Hold Timing" in the Advanced Fitter setting in the Compiler Setting.
Richard Tan
