DWEIS9
7 years agoArria 10 GX FPGA Development Kit - standalone clock configurarion.
Arria 10 GX FPGA Development Kit has 2 clock sources (Si5338).
They are programmable by "Clock Control" application running on PC. Configuration is not saved to NVM and needs to be repeated every power up.
Please suggest a solution for that clock configuration Si5338 will be restored / configured automatically at power-up.
1 Reply
- Rahul_S_Intel1
Hi , The whole configuration is done through the Max V System controller, if you can change the settings of Max V system controller by switch 6 that will enable the setting to load from flash, that mean to say you can control the clock select from Flash. Regards, Rs
