DWEIS9
7 years agoArria 10 GX FPGA Development Kit - standalone clock configurarion.
Arria 10 GX FPGA Development Kit has 2 clock sources (Si5338). They are programmable by "Clock Control" application running on PC. Configuration is not saved to NVM and needs to be repeated every po...
Rahul_S_Intel1
7 years agoHi ,
The whole configuration is done through the Max V System controller, if you can change the settings of Max V system controller by switch 6 that will enable the setting to load from flash, that mean to say you can control the clock select from Flash.
Rs
