StefanoC
4 years agoALMs vs combinational logic gates
in the compilation report, I don't understand how the number of used combinational gates plays against ALMs.
Originally I had a function that used several +/* on float64 and compiling that (...
Ash_R_Altera
4 years agoHi,
As I understand your query, you are seeing a drastic reduction in utilization of ALMs after changing the code from function to a component.
I suspect that there is something missing in the code and that the logic is being removed. Recommend to review check all the connections to the component in the HDL. To confirm, use the Technology Map Viewer and see if really the logic got implemented or not.
StefanoC
4 years agothat was right, the actual result from the component wasn't assigned to an output pin and I believe the compiler wasn't actually placing the thing, so problem solved.
