[Agilex}:Issue with Ping Command on I210-T1 Ethernet Server Adapter
- 2 years ago
Hi Intel Communities,
Thank you for your response.
Here are the details you requested:
Intel Ethernet I210 Specifications: I am using an Intel Ethernet I210-T1adapter(1Gbe,Single Port,Copper,RTL Single)
Driver Version for Ethernet and igb: The version of this driver is 6.1.38-243710-g50b63a962d02-dir. The firmware version is 3.25, 0x800006eb.
Kernel Version: The Linux kernel version I am currently running is 6.1.38-243710-g50b63a962d02-dirty.
Thanks & Regards
Satrasala Raju
Hello raju1421,
Kindly go thru this site Linux* Base Driver for Intel® Gigabit Ethernet Network Connections to get the latest driver for the IGB.
You can also go thru Intel® Ethernet Adapter Complete Driver Pack to get your driver updated to latest - if you haven't done so.
Kindly go thru the readme files for both driver as it will give you more insights.
Can you please confirm that you have the updated kernels?
Kindly get back to us with the errors if you have after all is updated.
Please let us know if you have any questions.
Thank you.
Hayat
Intel Customer Support
