yans3
3 years agoAgilex I-Series FPGA dev kit, BTS programming failed
We have been testing with our Agilex I-Series FPGA with the provided board testing system.
We have set all the default switches to the default position, and we are using the FPGA as a PCIe-c...
NurAiman_M_Intel
3 years agoHi,
Please check the serial number on the dev kit. Make sure it is compatible with the programming device.
Eg: If you use DK-DEV-AGI027R1BES, then the programming device must be AGIB027R29A1E2VR3.
If DK-DEV-AGI027RES was used, then the programming device must be AGIB027R29A1E2VR0.
Aiman
- yans33 years ago
Hi Aiman,
I tried the BTS on another system with the same FPGA, here is the full log of BTS. It seems that the BTS bitstream does not match with the FPGA?
Let me know if you need other information.
Best,
Yan
