yans3
3 years agoAgilex I-Series FPGA dev kit, BTS programming failed
We have been testing with our Agilex I-Series FPGA with the provided board testing system.
We have set all the default switches to the default position, and we are using the FPGA as a PCIe-c...
NurAiman_M_Intel
3 years agoHi Yan,
Apologize for the delay in response.
Per my understanding you are having problem with while running BTS for AGILEX I-series dev kit.
- Make sure you are using the correct BTS. Which is for Agilex I-series.
- Can you provide screenshot from BTS GUI?
- Make sure the BTS are connecting correctly to the board.
Aiman
yans3
3 years agoHi Aiman,
1) Yes, we encountered issue with running BTS for Agliex I-series dev kit.
2) We have checked the BTS is the correct one that corresponds to the Agliex I-series FPGA.
3) Screenshots from BTS GUI is attached. The last image shows that configuring the GPIO design failed at 99%, and a screnshot from the terminal is attached in the first post.
4) We connect the FPGA with the PCIe gen5 x16, the micro-usb port, as well as the 6+2pin power.
Let me know if you need other information.
Thank you,
Yan
