Avichay
4 years agoAgilex F tile the FGT Xcievers REFCLK
Hi, We use on the Agilex F tile the FGT Xcievers with AC coupling.
Intel Agilex datasheet below requires differential p-p voltage of 1.2V. please see attachment .
In the eval board we saw th...
AqidAyman_Altera
4 years agoHi,
From what I understand, voltage swing is specified as single-ended mVpp while in the Agilex Datasheet it shows the Vdiff AC as Vpp-diff.
Vpp_diff = 2*Vpp_se
So, based on the LVDS in the Silicon labs datasheet, it shows 430mVpp_se typ. If we calculated according to the formula above, we got 860mVpp-diff which are still in the range of specification stated in Agilex datasheet.
Aqid
