Zhilang_X_Intel
5 years agoAgilex F P-tile Debug Toolkit shows no DUT listed after design loaded
Issue Description: I enabled 'Debug Toolkit' feature of P-tile AVST PCIe Hard IP in Quartus and could see the PCIe endpoint in Linux, but No DUT listed in System Console after Load Design.
Tried Qu...
Deshi_Intel
5 years agoHI,
Can you try pull "p0_hip_reconfig_clk_clk" to your top level project file and assign to input clock pin as suggested by the P-tile user guide doc ?
Also ensure your Agilex dev kit board is supplying correct clocking frequency to both the reconfig_clk pins.
The other thing that you can check is to verify reconfig_reset signal if available is not stuck in reset also.
dlim
