Agilex Board Test System difficulties
- 3 years ago
Hi WWood7,
Sorry for the delay in response. I was trying to do some research internally regarding this issue. Here are some steps you can give a try first and see if it works:
1. Could Download the BTS installation files from our website : https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/i-series-transceiver/si-agi027.html
select ES2 (if you are using an ES2 version of the board). Once downloaded please try to update with the following .pof
\examples\max10_system\max10_system\output_files\max10_system.pof
2. Please restart computer and power cycle the dev kit before you configure.
Let’s see if these works, I will try to come out with another debugging step soon.
Fakhrul
Hi WWood7,
Fakhrul
Dear Fakhrul,
Thank you very much for your quick reply. The BTS files you mention are the ones I am using. But I was using the max10_system.pof in the "system_restore" folder (or whatever it's called, I forget exactly). When I used the one you mentioned, the BTS works! Even the QSFPDD800 program is running now. Thank you for helping me get this started!
One question ... I guess I have an ES2 version of the board, since the program is working, but how do I know for sure? My FPGA is AGIB027R31B1E1VAA and the board serial number is AGI87TS0001137.
Many thanks again,
WWood7
