Agilex Board Test System difficulties
- 3 years ago
Hi WWood7,
Sorry for the delay in response. I was trying to do some research internally regarding this issue. Here are some steps you can give a try first and see if it works:
1. Could Download the BTS installation files from our website : https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/i-series-transceiver/si-agi027.html
select ES2 (if you are using an ES2 version of the board). Once downloaded please try to update with the following .pof
\examples\max10_system\max10_system\output_files\max10_system.pof
2. Please restart computer and power cycle the dev kit before you configure.
Let’s see if these works, I will try to come out with another debugging step soon.
Fakhrul
Hi WWood7,
This issue is somehow related to this KDB: Why is the Board Test System (BTS) GUI unable to locate the USB-Blaster?.
Could you check whether you're using the same version of Quartus and BTS?
As for the JTAG issue, kindly refer to the following KDB as it maybe applicable to your current issue:
Error (209053): Unexpected error in JTAG server --error code 44
Error (209053): Unexpected error in JTAG server -- error code 126
Hope this would works!
Fakhrul
Hi Fakhrul,
I am in need of a solution, or a replacement board. Could you let me know what my options for paid support are? Perhaps you could e-mail me with that information?
