Agilex Board Test System difficulties
- 3 years ago
Hi WWood7,
Sorry for the delay in response. I was trying to do some research internally regarding this issue. Here are some steps you can give a try first and see if it works:
1. Could Download the BTS installation files from our website : https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/i-series-transceiver/si-agi027.html
select ES2 (if you are using an ES2 version of the board). Once downloaded please try to update with the following .pof
\examples\max10_system\max10_system\output_files\max10_system.pof
2. Please restart computer and power cycle the dev kit before you configure.
Let’s see if these works, I will try to come out with another debugging step soon.
Fakhrul
Hi WWood7,
First, I'd like to know more about the issue and your application to have a better understanding and narrow it down to possible causes. If you can answer the following questions I'll appreciate it.
Can you try a simple design with POF/SOF? just to find out if problem is POF dependent.
May I know if this is a singular case or are you seeing the same issue in other new devices?
Fakhrul
Also, in case it is relevant, I seem to have an an occasionally intermittent JTAG connection. When I run Programmer (22.3.0 build 104) I sometimes get the following error message when I try to load an SOF:
Error(209053): Unexpected error in JTAG server -- error code 2.
Similarly, "jtagconfig" sometimes returns "JTAG chain broken" at the command line.
In both cases, just running the command again is enough to load the SOF. The connection seems OK but can be a little flaky. Replacing the USB cable with a new one didn't help.
I cannot find any documentation on Error 209053.
