snehal_pContributor3 years agoAdding HPSGPIO/LOANIO to the signal tap analyzer Hello, Can we add hpsgpio/loanio to the signal tap analyzer. I tried adding, but getting fitter error while compiling. Thanks, snehal_p
sstrellSuper Contributor3 years agoIf the signals show up with the Signal Tap filters in the Node Finder, then they can be tapped. What error are you getting (full message)?
Recent DiscussionsAXE5-Falcon using the J8/J9 MIPI connectors?SolvedInstaller Package for DK-DEV-10AX115S-BDE2-115 Nios VGA demoAgilex 5 E-Series 065B Premium Dev Kit - is FPGA_3V3_SDA/SCL driven by an HPS I2C controller?Help needed to start PAM4 loopback test on Stratix 10TX-SI Kit
