JLIU45
6 years agoAbout Arria V LVDS output
I'm uising arria V device in my project, a pair of LVDS pins are used in my design, which are configured as output. It always cannot work well, and by using OSC I watched the output waveform of LVDS ...
SreekumarR_G_Intel
6 years agoHello,, sorry for delay in response.
There should be common mode voltage in the LVDS bus which i didnt see in the graph you sent me.
can you check the LVDS std is set correctly ?
Thank you,
Sree
- JLIU456 years ago
Hi, thanks. I just set the I/O standard to LVDS in pin planner, always I do like this, and it works well besides this case. For Arria-V device, is there any other special configuration for LVDS pin?
