johnt2
2 years ago3-Wire SPI IP Component with Arria 10
I am trying to implement a 3 wire SPI on a Arria 10 for our HPS. I found a post with a link to this page: https://www.intel.com/content/www/us/en/docs/programmable/683113/21-3-19-2-0/generating-the-d...
aikeu
2 years agoHi johnt2,
From the link you have provided showing the JESD IP screenshot, You can select one of the two default JESD204B example designs(bottom right of the screenshot which is part of Library example design files), then select/tick generate 3 wire SPI module to generate the example design which consider the 3 wire SPI module in the connection. The created example project then can be viewed with platform designer for reference.
Aik Eu
