amaltaha
4 years agoWeird behavior of dpc++ code after running it on FPGA device
Hello, I am using DPC++ to accelerate knn algorithm on FPGA device. The following code is the code I wrote for the euclidean distance. The problem is that the fpga_emulation works very well with n...
- 4 years ago
Hello Aik Eu,
Thank you for your reply, I removed the no_init from the accessor and is now working correctly as expected.this line:
accessor dif(res_buf, h, write_only, no_init);became this:
accessor dif(res_buf, h, write_only);Thank you!
