messn036
4 years agoSample project with RTL module library not working
Hello Intel Support,
I am attempting to compile a library of RTL components to use in my HLS project.
The HLS project compiles when testing for x86-64 simulation, but the compiler complains about...
- 4 years ago
The issue is in my expHBU.h file. I put
uint8_t expHBU(uint8_t input);Rather than the CORRECT
extern "C" { uint8_t expHBU(uint8_t input); }This extern is extremely esoteric and should be included in the reference manual.
messn036
4 years agoi++ component_testbench.cpp expHBU.a -v --dont-error-if-large-area-est -march=Cyclone10GX -o test-fpga Target FPGA part name: 10CX220YF780I5G Target FPGA family name: Cyclone10GX Target FPGA speed grade: -5 Resolved expHBU.a to /home/grads/messn036/OpenCL-HUBERT/OpenCL-HUBERT/component_ip/expHBU.a Analyzing component_testbench.cpp for testbench generation Creating x86-64 testbench Analyzing component_testbench.cpp for hardware generation Verifying version information in the included files. Expecting version 21.2.0.67.4 for all included files. Included files passed version check. Checked: /home/grads/messn036/OpenCL-HUBERT/OpenCL-HUBERT/component_ip/expHBU.a Preprocessing FPGA Libraries Optimizing component(s) and generating Verilog files component_testbench.cpp:9: Compiler Error: undefined reference to 'expHBU(unsigned char)' HLS Main Optimizer FAILED. make: *** [test-fpga] Error 1
I have done some basic troubleshooting in the meantime an narrowed down my error a bit. To compile the RTL library, I am using the following commands
fpga_crossgen exp_wrapper.xml --target hls --emulation_model expHBU.cpp -o expHBU.o fpga_libtool --target hls --create expHBU.a expHBU.o
But It seems like I need to use different flags to get the xml and verilog to compile for NOT the x86-64 simulation but for the test-fpga version. Am I right here? When should I expect to compile the xml and verilog?
