lkljucaric's avatar
lkljucaric
5 years ago
oneAPI FPGA Compile Node Errors
I am currently experiencing errors when trying to compile FPGA designs using oneAPI. The errors I'm seeing: " Error: Compiler Error, not able to generate hardware llvm-foreach: dpcpp: error:...
  • Mickleman's avatar
    4 years ago
    Hi @lkljucaric
    I had the same problem which was resolved as follows on advice from Intel.
    In the build script add a line at the beginning to ensure that the correct version of Python is used - here is the script I am now using:
    #!/bin/bash
    export PATH=/glob/intel-python/python2/bin/:${PATH}
    source /opt/intel/inteloneapi/setvars.sh > /dev/null 2>&1
    make hw -f Makefile.fpga
    Hope this works for you as well.
    Kind regards
    Marcus
Recent Discussions
