Intel BD-NVV-N3000-2 issue
1. Confirm that you are running at maximum fan speed
2. Does the card shutdown even at idling? if no, you may want to check with your workload developer how to reduce the workload.
Hi Jonway,
Fans are running on normal mode.
Yes server is in idle mode.
- samir_bhansali6 years ago
Hi Jonway,
Below is the attached output from supermicro server when immediately run the command after booted to OS for your reference.
But after OS booted later on the output is different.
- JonWay_altera6 years ago
I think this further confirmed that you dont have enough airflow.
When you first booted into OS, the card is still working but very near to shutdown temperature.
(12) FPGA Die Temperature : 96.50 Celsius
After a while, when the temperature exceed 100C, it will shutdown, and you wont get any reading.
The card is fine and working as expected. The problem is that you dont have enough airflow to the card. You will need to check with the server vendor on how to improve airflow to the pcie slots devices.
