Ric2
2 years agoHi again, I'm going to add some more specifics to the problem decribed above. As said, we intend to implement an Avalong Streaming interface with the sycl HLS (icpx) workflow.
The Avalon Streaming specification has this definition for the dataBitsPerSymbol parameter:
The icpx error (Report generation) for non power of 2 numbers is
[ 66%] Building CXX object CMakeFiles/report.dir/src/streaming_data_interfaces.cpp.o [100%] Linking CXX executable streaming_data_interfaces.report Compiler Error: The data type carried by _InStream exceeds the bits per symbol. You can either enable the sideband signal 'use empty' or increase the bits per symbol. Error: Optimizer FAILED.
Note 1: The error is generated after compilation of the source files while linking.
Note 2: EMU generation of non power of two numbers works.
Note 3: With Intel HLS (i++) project it was no problem to generate this non power of two width Avalon Streaming interfaces.
Hope that helps to identify (and resolve) the problem reported.
