Thanks @MGRAV
I'm not sure I quite understand what you are suggesting. If you could give me a version of the example changed as you propose I will try it out and feed back the results.
maybe something like this, and even I don't know if the compiler can figure out
const int ITEM_LENGTH = 10000;
const int GROUP_SIZE = 10;
uint16_t a[ITEM_LENGTH][GROUP_SIZE];
uint16_t b[ITEM_LENGTH][GROUP_SIZE];
[[intel::ivdep]]
for (int k = 0; k < GROUP_SIZE * ITEM_LENGTH; k++)
int i = k / GROUP_SIZE;
int j = k - i * GROUP_SIZE;
if ( i == 0 )
a[i][j] = j;
else
a[i][j] = a[i-1][j] + i;
[[intel::ivdep]]
if ( i == 0 )
b[i][j] = j;
else
b[i][j] = b[i-1][j] + i;
But what the problem with the two loops if it work ?
